Why this mikroC PRO PIC code not working?
milan.rajik
Banned
Advanced Member level 5
It has to extract data between 2nd space char and 1st encounter of 'M' from there for first function call and for second function call it has to get data between 3rd space and first appearance of 'G'. It is working fine for 1st function call but dosen't work for subsequent calls.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
char teststr[] = "AF/CCT1456 12;22pp XX.XXM YY.YYG"
char tempBuff[20], temp[20];
void SplitBuff(char *to, char *from, char delimit1, unsigned char delimit1Count, char delimit2, unsigned char delimit2Count, int lenBuff, char *tmpBuff){
          unsigned delimit1Cnt = 0, delimit2Cnt = 0;
          unsigned char tmp[2];
          tmp[0] = delimit1;
          tmp[1] = '\0';
          strcpy(to, strtok(from, tmp));
          while(++delimit1Cnt != delimit1Count){
                   strcpy(to, strtok(0, tmp));
          memset(to, '\0', lenBuff);
          tmp[0] = delimit2;
          while(++delimit2Cnt != delimit2Count){
                  strcat(to, strtok(0, tmp));
          strcpy(tmpBuff, to);
void main() {
    while(1){
        SplitBuff(&tempBuff, &teststr, ' ', 2, 'M', 1, 20, &temp);
        SplitBuff(&tempBuff, &teststr, ' ', 3, 'G', 1, 20, &temp);
Try initializing teststr[]= "AF/CCT1456 12;22pp XX.XXM YY.YYG" again inside while (in main function).
I mean
void main() {
    while(1){
How does it solve the problem? I mentioned it works when the function is called 1st time but subsequent calls doesn't work. Anyway mikroC doesn't allow to initialize arrays inside functions. It gives "Invalid expression" error.
Even this code behaves the same way.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
void SplitBuffer(char *to, char *from, char delimit1, unsigned char delimit1Count, char delimit2, unsigned char delimit2Count, char *(*mystrcat)(char *, char *), char *(*mystrcpy)(char *, char *), char *(*strtokn)(char *, char *), void *(*mymemset)(void *, char, int), int lenBuff, char *tmpBuff) {
          tmp[0] = delimit1;
          tmp[1] = '\0';
          (*mystrcpy)(to, (*strtokn)(from, tmp));
                   (*mystrcpy)(to, (*strtokn)(0, tmp));
          (*mymemset)(to, '\0', lenBuff);
          tmp[0] = delimit2;
                  (*mystrcat)(to, (*strtokn)(0, tmp));
          (*mystrcpy)(tmpBuff, to);
void main() {
    while(1){
        SplitBuffer(&tempBuff, &teststr, ' ', 2, 'M', 1, &strcat, &strcpy, &strtok, &memset, 20, &temp);
                SplitBuffer(&tempBuff, &teststr, ' ', 3, 'G', 1, &strcat, &strcpy, &strtok, &memset, 20, &temp);
I don't get any error for my code. I am attaching my mikroC project files. Debug and see it yourself. I will explain according to code in post #3. The 1st time the function executes the result is as expected but when the function is called 2nd time everything works fine till 11th line in post#3 code. After that no data is copied to the string pointed to by to (string).
If the 1st function call is commented out and 2nd function call is executed then result is again fine. So, function works only once.
Edit: See attached video. It shows code debugged. See what happens during 1st call and 2nd call.
  • Function Test.rar
  • func dbg.rar
When passing or storing a pointer to the first element of an array, the name/symbol of an array contains the address of the first element.
Therefore, use of the address operator (&) is not required:
char a[20] = "Testing";
char * pstr;
pstr = a;
// pstr[3] now contains  't', pstr[0] now contains to 'T'
BigDog
Post #5 is updated. Video of debug attached.
@bigdogguru
What am I doing wrong? Should I remove & in then function call arguments and try?
Double check your string array sizes, the receiving string array must be large enough to contain the resulting string.
See your other thread.
BigDog
