rcxfs assura
why some layers missed in the extracted view ?
i put a MOS with it's d and s connected to ground, then layout, drc, lvs, and finally extracted.
but some layers missed in the extracted view of av_extracted, such as the poly layer.
i attached those snapshots in this post.
at the same time, i found some message unusual in CIW when it loading tech rule set file as i start the RCX :
\o *Info* Ignoring overWriteRuleSets from the State File
\o *Info* Ignoring selectedRuleSets from the State File
\o *Info* Ignoring selectedDirs from the State File
\o *info* Netlisting Option Virtual Metal Fill can take only "Shape"
\o *info* as a valid value when RCXFS is Enabled.
\o *info* Limiting Virtual Metal Fill value to "Fine Shape"
\o *info* Your RCX Setup Value for Virtual Metal Fill will be ignored.
\o *Info* Ignoring rcxNets from the State File
\o *Info* Ignoring rcxNetsFromFile from the State File
\o *Info* Ignoring rcxNetsFile from the State File
\o *Info* Ignoring rcxFSNets from the State File
\o *Info* Ignoring rcxFSNetsFromFile from the State File
\o *Info* Ignoring rcxFSNetsFile from the State File
\o *Info* Ignoring fixedNets from the State File
\o *Info* Ignoring fixedNetsFromFile from the State File
\o *Info* Ignoring fixedNetsFile from the State File
\o *Info* Ignoring inductanceNets from the State File
\o *Info* Ignoring inductanceNetsFromFile from the State File
\o *Info* Ignoring inductanceNetsFile from the State File
\o Load complete.
could any body tell me how to solve this problem ???
i'm using the ic5141usr1 and the assura 314 with chrt 0.18 process.
thank you soooooo much !!!
