hem_wall said:can u please tell why silicon is used in all applications then germanium
Hello,
The advantages of Si over Ge are:
=> Stable and strong material & crystal structure like diamond
=> Si has a wider bandgap than Ge
=> higher operating temperature (125-175 oC vs. ~85 oC) and thus become intrinsic at higher temp.
=> Si readily forms a native oxide (SiO2) high-quality insulator protects and “passivates” underlying circuitry helps in patterning useful for dopant masking.
=>Large variety of process steps possible without the problem of decomposition (as in the case of compound semiconductors)
=> Si is cheap and abundant
Paramjyothi
There are others too. For example gallium arsenide has been used for many years, and is better than silicon for some applications such as microwave devices.can u please tell why silicon is used in all applications then germanium
One of the points you mentioned is that Silicon has a larger band gap than Germanium, in what way is this better?
