Why power does not amplify?
kohtwe
Junior Member level 2
Why don't power amplify
What answer?
Re: Why don't power amplify
kohtwe said:
What answer?
i couldn't understand the question posted by you..plz redefine it so that we will be able to answer it...
Hi Everybody,
I think kohtwe mean "Why amplifier didn't amplify power?"
In general, the purpose of an amplifier is to take an input signal and make it stronger.
Amplifier can amplify powre.
Plz any comment ???????????????
more info: http://www.rocketroberts.com/techart/amp.htm
ZAW
Current or Voltage are amplify. Why don't power amlify?
kohtwe,
Power gain equals output power divided by input power. For example: An amplifier has a 1000 Ohm input resistance, a voltage gain of 10, and an output load of 100 Ohms.
Assuming the amplifier is operated in its linear region, the following relationships hold:
Input power = Vin^2/1000
Output power = Vout^2/100 = (Vin X 10)^2/100
Power gain = [(Vin X 10)^2 / 100] / [Vin^2/1000]
~ = 1000.
The power is amplified by a factor of 1000.
Regards,
Kral
in my opinion (i m not sure), when u amplify voltage, u r amplifing power (the context seems wrong anyway),,
power=VI (i m not considering time)
b/c u r amplifying ur voltage by consuming ur battery power, amplifier don't sinks the source of signal for amplification..
if i m wrong, kindly let meknow...
Naveed Alam,
Consider the following example:
An amplifier has an input resistance of 10K Ohms, a gain of 2, and a load resistance of 100K Ohms.
With a 1 Volt input, the output voltage is 2 Volts
~ The input power = (1^2)/10000 = .0001W = .1 mW
~ The output power = (2^2)/100000 = 4/100,000 = .00004W = .04 mW
~ The power gain = .04/.1 = .4 => -3.9794dB.
Regards,
Kral
As far as I know ,the basic operation of a power amplifier is to amplify both current as well as voltage.So if we want to find the power gain,it is current gain into voltage gain.
neils_arm_strong,
Power gain = (Output Power) / (Input Power). In some cases, power gain is not a useful parameter. For example, if an amplifier has infinite input impedance, and a finite load, the input power would be zero, and the power gain would be infinite, but this does not have any practical significance. However, in many RF applications, you are working with a specific characteristic impedance, e.g., 50 Ohms. In these applications, both input power and output power have significance.
regards,
Kral
hi Kral..
so, it means that power amplification exists..interesting for me!!!!
some one said here that amplification means that current and voltage both amplifies.. this is not essential..there are amplifiers which amplifies both, but some amplifies only voltage..for reference read , COMMON-BASE, COMMON, EMITTER, AND COMMON BASE amplifiers.....
Regards
in case of power amplifiers,we are always concerned about its efficency and least bothered about gain..why it isonly a stepmother treatment for gain ..i couldn't understand...
There is no power amplification in the truest sense. Law of conservation of energy implies that no new energy can be generated. So the power amplification we are talking is only AC power amplification. An AC signal can be voltage, current or power amplified. The power required for this power amplification comes from the DC battery supply.
Here comes the concept of efficiency, which determines how much of the battery power is actually used for AC signal amplification and how much is dissipated in the devices.
Hi....
I also think as lavitaebelle !! ! !
To amplify a thing (eg:voltage or current),we will lost other one thing.
But this is only my suggestion.
Any comment are welcome!!
NO, this is property of transformer..amplifiers do amplification at the cost of Battery..so, no need to reduce the other one..
Regards
Like someone already said, amplifiers run off power. The power delivered to the signal / power used from the source is the efficiency. No new "power" is created, Only used.
Power can be amplified. This is where the concept of power amplifiers comes into picture.
If you amplify voltage definitely the output power defined by Pout=Vout*Iout will be more than Pin=Vin*Iin. And so you have amplified power.
...there exists a lot of difference between Voltage amplifier and power amplifier...both cannot be equated at any time
