Why poly silicon is used at the gate of mos?
sabu
Junior Member level 3
y poly silicon is used at the gate of mos,shall i know the reason from u
thanks in advance
sabu
ssuchitav
Re: poly silicon
HI!
Two reasons i know at this time..
1) no electromigraton
2) accuracy of VT ( Threshold voltage)
others u can collect from VLSI Technology by S.M.Sze and VLSI fabrication principles by S.K. Gandhi.
sabu
poly silicon
plz help me how 2nd happens
mobie
poly silicon
self-align
safwatonline
EGYPT
poly silicon
poly can be heated in very high temp. will metal "as Al" will propably diffuse through silicon "i think this is the main reason", poly can be doped and hence we can control its c/c's Vth .
poly is bad in terms of conductivity "smaller than metal", i think that we may return to metal eventually when the VLSI technology advances more and more.
Added after 1 minutes:
btw the diffusion of Al in silicon is bcause AL is soluble in Si "i think so is Cu"
