realtek
Member level 5
does intel use latch based design
If your circuit is asy circuit
maybe use latch is a good way to perform asy circuit design
but be sure to check if your coding style can be accepted by synth
(such as DC)
if DC not synthesis your RTL as latch
then set synopsys translate off to this latch module when synthesis
use gate level to design the latch which you need
It's not absolute that can not use latch in design.
(such as DC)
