ise_lewis
Newbie level 3
I use the following constraints :
set_clock_uncertainty 0.2 [find clock scl1]
set_clock_latency 0.5 [find clock scl1]
set_clock_transition 0.5 [find clock scl1]
constraint report the violations
min_delay/hold ('scl1' group)
Required Actual
Endpoint Path Delay Path Delay Slack
I3/I31/buffer_reg[0]/D 0.56 0.00 r -0.56 (VIOLATED)
I3/I31/rd_reg/D 0.68 0.42 f -0.25 (VIOLATED)
I3/I31/nack_reg/D 0.59 0.34 f -0.25 (VIOLATED)
When I increase value of set_clock_latency, violated value also increase.
I don't know why is violated?
Required Actual
