Why is it that in a cascode LNA, only the input transistor contribute to the noise?
boshiouke
Junior Member level 3
Why is it that in a cascode LNA, only the input transistor contribute to the noise, while the cascode transistor doesn't? Thank you.
vfone
Advanced Member level 5
Re: cascode LNA
If the parasitic capacitance of the node between cascaded LNA’s is high, the noise contribution of the second LNA could be significant at high frequencies.
boshiouke
Re: cascode LNA
Thanks for the reply, vfone.
In CMOS LNA, since noise current is proportional to gm, the cascode transistor's gm is degenerated by input transistor, so I suppose that explains why it contributes less. But how about bipolar LNA? The shot noise is 2qI. How does it work over here? Thanks.
zigbee2005
Newbie level 6
cascode LNA
you can find the answer in the Razavi's book.
