They can, and new GSM topologies do use a single VCO for both bands. You have to be concerned about lock time and the GSM class that you support through.
GSM class refers to the number of slots that you can use for receive and transmit. If you can't get a PLL to lock fast enough, then you will need to use a seperate RX and TX so that you can toggle between receive and transmit.
