Zluo
Newbie
I'm trying to design a microwave filter with coaxial-SIW structure. Basically, it's a coaxial line with shorted one side surrounding by SIW. The length of the line is less than 1/8 lamda that's why it can be represented by an inductor. On top side, there is a big lumped capacitor, see picture below. That's how a resonator was buildup. However, when I try to use HFSS eigenmode to analyze the design, I can only find SIW waveguide mode but no TEM coaxial mode can be recognized.
Then I turn back to HFSS modal and do spectroscopy. From S21, see below, i can see the resonance clearly located at around 7.3GHz with coaxial mode. However, the smallest resonance frequency by Eigenmode is around 15GHz with waveguide mode.
Could some one help me on this? Do you have similar problem with eigenmode?
