why get negative gain value?
walker5678
Full Member level 3
common source, negative gain
I am designing an op amp with folded cascode input stage , and a push pull common source output stage. But after hands on calculation, i run spice simulation, and the result showes minus gain value.
What's the problem might be?
why get minus gain value?
post ur schematic
Re: why get minus gain value?
the circuit[/img]
I dont understand what is the problem with negative gain ??
The opamp is inverting, a common source input stage has a 180 degrees shift..
Nice circuit by the way, I like the low voltage current source..
You mean you ar getting a -ve gain in dB?
You need to check the operating regions of the transistors ( be sure they are all region 2 )
If this is OK, then I think you need a closed loop simulation ( perhaps using stability analysis "stb" in Cadence ). The class AB output stage is most probably unstable ( you cannot guarantee both N and P MOS are in saturation in quiescent mode, due to current mismatc between the two )
Hope this helps...
    walker5678
when i check the DC operating point, found the out voltage was driven to close Vcc(4.4V), and some transistor in the circuit seems out of saturation region.
I think i should re-decide the W/L ratio of the transistors.
hi
plz try to increase biasing volatges.
if then problem persisits then it would b problem with soft u r using
It's the model related problem, i changed model files and got the resonable result.
1)The CKT is typical ClassAB.It need balance @M16,M17,M18,M19,M20,M21.
2)Use the RC is better than C only for compensation.(10pF is too large)
3)In the low voltage current source ,how to ensure the commond gate operation at satuation region ?
hi, fendy
Thanks for your advice.
For the low voltage current source, Vg(M7, M9)=Vth+Von, (where Von=Vgs-Vth), and Min. Vg(M6,M8)=Vgs6+Von7=Vth+Von6+Von7=Vth+2Von(cause W6/L6=W7/L7=W8/L8=W9/L9).
So the voltage drop on the resistor R0 is Von, set your Von ( for example, 0.25V) and calculate R0 by current. Then calculate W/L of M6,7,8,9. The voltage on the drain of M8 can be as low as 2Von, which is 0.5V.
