why fixed frequency current mode buck dc to dc converter damage chips which use it
edisonliu
Junior Member level 3
I am debugging the issue as the tittle. The dc to dc output high votage sometimes. But we can not catch it. We guess there is some high voltage because the class d amplifier use its output as power is damaged. The amplifier power pad is damaged. Could somebody give us sone clue about it? Thanks very much.
You would have to induce the (intermittent) problem and
capture it to understand.
You might look at load-dump (or loud-to-quiet) transitions
to see if there is an unacceptable overshoot on that load
step. See if the converter can be driven into current-limit
at max Class D load, perhaps winding up the control loop
and resulting in cross, non-small-signal overshoot when it
releases.
Power-up can also induce overshoots especially if soft
start ramp is faster than loop bandwidth limited control-
loop slew.
    V
