Why first order modulator limited to 1-bit quantizer?
neoflash
Advanced Member level 1
Why it can't use multi-bit quantizer?
Thanks.
sumit_techkgp
Full Member level 2
You can use a multibit quantizer. Where are u using, it depends on that!. What is the application ?
neoflash
It is for fractional-n sythesizer. Does it matters?
sumit_techkgp
Full Member level 2
U have a DAC. One bit DAC is a simple switch. More than one bit involves nonlinerity. Thats the reason. One bit circuit has lesser nonlinearity.
mike_bihan
Full Member level 3
This says it is a soft limitation and not a hard one. We can still go multi-bit quantizer in 1st order MOD, at the cost of higher non-linearity, right?
Added after 1 minutes:
by the way, the sigma-delta modulator is in digital domain for frequency synthesizer, so there is no limitation on DAC linearity.
