why does nt my pic work at 20Mhz
roykyn
Full Member level 5
20mhz pic crystal
please help me.....
i am using 16f72 pic.....on a bread board......it works perfectly at 4.433619Mhz but when i insert a 20Mhz crystal it doesnt work.....i am using mplab 7.41 and jdm programmer... i have also grounded the crystal metal case....
ya i changed the config bit to hs its working now....
but i have another problem now...i need very accurate 4.194304 Mhz source...i am using crystal for that.....now i dont know the exact value of the parallel capacitors for satbilization
i dont have the datasheet of the crystal...... 4.194304 kds 2c is written on the crystal....
aviv6371
Member level 2
20mhz load capacitor
when using 4 mege crystal you work withe XT mode . the HS mode designed for high speed crystals. program the configuration bit of oscillator to HS.
16F676
Member level 2
aviv6371 is correct .
and one more thing to keep in mind that if your program is time based and configured for a 4 Mhz speed, it may not work higher value crystels.
for example: If you are comunicating the pic with another device in a specific speed, it may not work on higher speeds until you change the code or boad rate.
good luck
roykyn
Full Member level 5
aviv6371
Member level 2
try connecting 2 parallel ceramic 22pF capacitors o the 4 mega crystal
avi.
Alliegro
Member level 3
you get crystals with inbuilt capacitors. Small package. So you will not require external stablisation. If you require very acurate crystal stablised for temparature variations, you would need a oven controlled crystal. Try AE electronics in Andhra.
roykyn
Full Member level 5
ya ocxo is a better choice.......even tcxo....is good......
any way i had tried 22pf in parallel but it changed the freq a little bit....the one without the capacitor was better.....i have seen in many websites.....they have suggested to calculate it using some load capacitance...since i dont know tat ...i have ruled it out.....
do u know the optimum value....cos i have seen using 2 diff caps with a variable capacitor on one side.......
aviv6371
Member level 2
the formula to calculate the capacitors is:
cl=(c1*c2)/(c1+c2)+cs
cl is load capacitor whice is mentioned in the data sheet
cs is the stray capacitor of the printed board typically 5pF
c1 and c2 is the parallel capacitors. usually its the same value
avi.
Added after 4 minutes:
one more thing ...for best stabilization connect potentiometer in serial from the output of the inverter/buffer to the crystal and tune it to get stabilliy and high starting performance.
avi.
blueroomelectronics
Advanced Member level 5
Toronto, Canada
roykyn said:
please help me.....
PICs running above 4MHz you have to be careful and not write to the same port twice in a row. Read up on PIC Read/Modify/Write... A real gremlin at high speeds.
Code Warrior
Full Member level 4
Connect very low value coil in parallel with crystal.
