Why does Design Compiler increase area when using a generate statement with condition
dw_man
Junior Member level 3
I am using a generate statement to instantiate a module which is causing an unexplained increase in are after DC synthesis.
I am using Verilog
The first snippet of code gives me a certain area
generate
   module_name instance name
endgenerate
I also get the same area if I don't use the generate statement.
When I use the second snippet of code, I get an increased area
generate
   if (1) begin
   end
endgenerate
Even if I use case statements with parameters inside the generate, I am getting the exact same number as the second snippet of code.
Is there a particular reason for this? Shouldn't this code be elaborated the same way?
