Why do we use floating wells instead of connecting them to the power supply?
road_0506
Member level 4
Phils
in layout designing, why do we use floating wells instead of connecting them to the power supply?
Re: floating well
that floating well might be used for isolating noise...and power supplies are noisy...
hence, connecting the well to the power supply will just make the well noisy...
    road_0506
Re: floating well
thanks sxunxs... i think you are right...
Re: floating well
When do we use floating nwell? nwell + pwell become diode, but nwell is floating. I think it will cause some problem.
floating well
Sometimes floating wells help you to avoid the body effect of PMOS transistors by connecting the source and the bulk tie together. The body effect increases the threshold of th transitor which impacts the performance of the transistor.
floating well
decrease the body effect on threshold voltage
