Why do we need verilog behavioural models ???
raghavkmr
Junior Member level 2
Why do we need verilog behavioural models ??? and then why we need to do its equivalence checking with Spice Netlist
andre_luis
Super Moderator
Staff member
Brazil
Because this way you can describe the working of a circuit in a simplest manner if compared to a structural model, releasing you of the task to predict all conditions and outputs covered by the designed circuit.
dick_freebird
Advanced Member level 5
USA
Behavioral models can do things that the limited set of
"compact models" (transistors & diodes and SPICE
internal primtives) cannot - those are fixed and only do
what was coded.
A blok where you only really care about the inputs,
outputs and their overt relation can solve much faster
behaviorally than in node-and-element detail.
But checking that those two are equivalent (enough)
is on you.
