Abraham900
Junior Member level 1
- Joined
- Dec 10, 2011
- Messages
- 17
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,425
Hello.
I'm currently, just for fun, trying to measure the resistance on an item that is class II (double insulated, not connected to earth that is).
I connect the black probe on earth/ground from the electrical outlet and the red probe on a metal screw on this item. The multimeter cannot read the ohm value on the multimeter since it is telling a 2V+ voltage is present on that area. So I measure the voltage and read 19VAC. Why is that? Does it have to do anything with introducing earthing to a double insulated item?
If I then disconnect the charger from this item and measure between earth and the charger output, I measure 70VAC! (It is supposed to deliver 12V). Why?
Grateful for some answers!
