Why do I get unsymmetric Mag E plot in HFSS?
Ruritania
Member level 5
I simulated an totally symmetric inductor in HFSS, but when I check the E field, I found that the plot is totally un-symmetric, I even can not see another port
!! (I changed the phase and do the annimation, but still found the unsymmetry).
Attached please find the Mag_E plot, thanks.
Ruri
i assume you defined two ports..not one defferentical port.
so only one port have been feeded signal..
What kind of port did you use?
Lumped port or waveport ?
Thank you, pengboy and costox.
I did define two lumped ports, using driven terminal solution type.
Did pengboy mean that I only need to define one differential port?
Regards,
Ruri
