Why do I get too big library setup time?
alexhugo
Junior Member level 3
I do a report_timing in dc_shell and I get a huge library setup time of -123.44ns
You can see the last part of the timing report:
Can you guess why a 40nm cell (FF) should have such a huge library setup time? clock period is 2.5ns
Thanks
Alex
node_1/index_reg/D (SDFQND2BWP) 0.00 0.57 r
data arrival time 0.57
clock mck (rise edge) 2.50 2.50
clock network delay (ideal) 0.00 2.50
node_1/index_reg/CP (SDFQND2BWP) 0.00 2.50 r
library setup time -123.44 -120.94
data required time -120.94
data arrival time -0.57
slack (VIOLATED) -121.51
report with transistion and capacitance also in time report that will explain to you
This is the new report with more information.
I don't understand how I can get rid of the library setup time.
Helps are greatly appreciated.
Problem is resolved.
I was using a control signal to OR with rst and reset all flops. The number of flops in terms of 100's of thousands and I couldn't set it like RST to be ideal network.
