why CML is know as current mode logic
manissri
Full Member level 5
the CML is known as current mode logic buffers.
what is the reason behind to say this as current mode logic as this the the diff amp with the passive resistive load
krashkealoha
Full Member level 1
I don't really know the history behind the name, but the VOH=Vcc and VOL=(tail current)*(load resistor). So the voltage swing is set by the current of the gate. Add an emitter follower then it is called ECL.
Sorry, I don't know if this helped.
wereiyou
Junior Member level 1
I was helped by your answer, thanks
safwatonline
EGYPT
cause it works by steering a current source
krishnareddy
because in cml current switching takes place rather than voltage switching
