Why can't we have intra assignment delay in Verilog code?
msumanreddy
Newbie level 5
why can't we have intra assignemt delay in continuous statement in the verilog code like
assign x = #5 clk
vinod_g
Member level 4
Re: verilog code
see first here x should be declared as wire . so the value is should be calcualted at the 0ns simultion time and the valuue have to assign after 5ns .so X is net not register ,hence illegal statement
rakesh1234
Member level 5
Re: verilog code
eeeraghu
Full Member level 4
Re: verilog code
The reg data type holds a value until a new value is driven onto it in an initial or always block. The reg type can only be assigned a value in an always or initial block, and is used to apply stimulus to the inputs of the DUT. The wire type is a passive data type that holds a value driven on it by a port, assign statement or reg type. Wires can not be assigned values inside always and initial blocks.
aslijia
Member level 2
verilog code
when synthesising, the tool will omit the timing delay automatically. so after that, assign x = #5 clk will be equal to assign x= clk.
