Why can't the higher-end faster devices have embedded flash ?
shaiko
Advanced Member level 5
Most microcontrollers today have internal flash memory from where the program loads.
However, the higher end faster devices ( sometimes from the same product family ) must use external memory to load from.
What is the reason for such a design ?
FvM
Super Moderator
Staff member
Bochum, Germany
Re: SRAM vs SRAM + FLASH
As far as I'm aware of, it's not a matter of speed rather than memory capacity. Higher end processors are often running embedded Linux, needing x Megabyte program storage. Typically, they also utilize external dynamic RAM.
As another point, high density flash and high speed processors seems not to go well together, technlogy-wise. But you still get self-contained single chip uPs in the high end segment from various vendors.
Referring to the question title (you didn't mention SRAM in your question at all), for highest execution speed, program code needs to be copied to SRAM.
shaiko
That's exactly what I meant - my question is - why ?
FvM
Super Moderator
Staff member
Bochum, Germany
It's what I hear frequently. It's also true for combining FPGA with flash. Altera said, if they would start a higher capacity embedded flash FPGA (> small MAX II/MAX V), it must be a multichip design. It's also obvious, that high end processors with flash have rather disappointing flash endurance data. Ask the semiconcuctor guys, why.
Reactions: shaiko
    shaiko
