allen_eadboard
Newbie level 1
why can't TetraMAX get right test pattern for path delay falut?
while atpg with TetraMAX for path delay fault model, it reports fault and test coverage is 100%.
Then when i simulate the test pattern in NC-verilog, it don't launch a transition in the corresponding path. And the way testing path delay is launch off capture.
The transcripts is that:
read_netlist *.v
read_netlist lib.v
run_build_model *
run_drc *.spf
set_faults -model path_delay
add_delay_paths *
add_faults -all
set_atpg -capture_cycles 2
run_atpg
write_patterns
thanks.
read_netlist *.v
read_netlist lib.v
run_build_model *
run_drc *.spf
add_delay_paths *
add_faults -all
run_atpg
write_patterns
thanks.
