Why are slots required in wide metal?
jelydonut
Full Member level 4
as the topic asks..
thanks
jelydonut
It helps to prevent dishing during the CMP process used in copper polishing.
What exactically is meant by dishing?
Also, if you have a 30um wide power ring and DRC rules dictate that say, 20um x 300um require slots.. do you have to put slots in the power ring? If you don't want could the concequences be?
jelydonut
Slots are used to satisly the maximum wire density technology rules. SO by using
slots you can control the wire densisty and meet the requirements
