We do use modulation when transmitting over long distances, but it is not worth the cost when distances are short. The simplest example may be the serial transmission from PCs, (RS 232) which uses antipodal modulation. And, I think the parallel port communication doesn't use any modulation.
if you think this info is useful click on "helped me" for statistics
Two type of modulation exist: Digital Modulation and Analog (RF) one.
Digital modulations (such as QAM or BPSK or...) are used to convert digital symbols to signal which is transferable.
Analog modulation as the other mentioned are used to far distance communication. antenna will propagates only if your frequency is high. Unfortunately I cannot remember its formula. I can only tell you the higher the frequency the furthur the distance. (look this sentence is not true for frequency above 10GHz)
in general, there are few communication media that can pass low frequency signals (baseband) without distortion, so that's why baseband signal is often "modulated" ('copy' the low frequencies to high frequencies) in order that it may be transmitted.
the loss is very high in baseband signal transmission due to this the modulation techniques are used, in digital modulation lots of effort are used to make the BER ( bit error rate) as low as possible.
There are two basic reasons why modualtion may be used:
1.antenna size is inversely proportional to (wavelength/4).
due to modulation,freq. increases,wavelength decreases and hence antenna size decreases.For basesband signals you would have to use very long antennas.
2.transmission errors are low and signals can be transmitted over longer distances.
typing error I think?....(it is directly proportional)
2. The baseband channel is not always in best shape to be transmitted e.g. more often
than not the channel is band pass and signal is low pass so one needs to transfer
the signal to a higher frequency
3. To add error detection and correction facility
Why Not
Increases cost and complexity
Isn't really needed for small distances
You can use base band transmition in short transmittion line,but when the length of wire extend,the signal fade, and at the same time, distortion will not decrease. At some point, the
signal will be coverd by noise, then you can not
recover the message without error.
