Note: This feature currently requires accessing the site using the built-in Safari browser.
zhi_yi said:in control engineering, we learn about transfer function, what is the "function" of the transfer function?
thanks..
zhi_yi said:hi all, thank you very much..
how about the discrete time? what is the discrete time? and why do we find the discrete time equation? what is the purpose?
thank you..
when using a matlab... it is easer if you present it in a transfer function.....why transfer function?
v_c said:By the way, the terms "input" and "output" can be confusing. Take for example the impedance of a network at a port. Impedance is the ratio of voltage/current. So current is the "input" and voltage is the "output". But these are measured at the same port -- so you have to be a little more careful. I tend to use excitation (instead of input) and response (instead of output), with the transfer function given by response/excitation.
thanks..
