Low active reset is maybe more common than High active reset but I can't see any particular reason why one i used more often then the other.
Good example here is the 51-family which uses High-Active Reset and so far no one have complained about it..
Reason for Active-Low lay somewhere in history and habits..
I dont know whether its true or not I heared this somewhere...
The reset pin is actually pulled low inside chip. So that by mistake
if you left it open then also the chip will be in reset; and this will
keep the flops which control tri state bus drives reset so as the bus gets
hiZ. and the tri stated io's get protected.
You must have in mind that bipolar transistors are inverters. If you think in this you can have an idea about why the reset signals are low active. Remember that semiconductor are builded with transistors. Regards.
active low reset is used to avoid the noise and signal interference issues in ASICs.now however active low is faster way to reset than active high.you can verify this with rise and fall time in any reference book
to me, here are three reasons.
1. in CMOS technology, if I don't get it wrong, the falling edge of a signal is sharper than a rising one.
2. for TTL/LVCMOS and some other standard, floating is somehow taken as a high by circuit, which will keep the circuit working other than reset if using low-active reset.
3. Personal habbits or library implies.
One possible reason is the Board design methods. Usually capacitor circuit is used for Power-On-Reset, such that the voltage at reset pin gradually goes to HIGH value. And by this time all reset activity is done.
More accurate answers are welcome.
