Who have example code for PID Control ?
SPATAN
Full Member level 2
PID Control
Please help me. MCS51 or PIC
raja_srs
Re: PID Control
Hello,
In what application your using PID Algorithm. Give details of your Quary. I already worked in this Algorithm in Temperature Controllers.
Cluricaun
Advanced Member level 2
Re: PID Control
Hi
Hi search for PID AND code, I hope there are anything usefull.
Here are some suggestions that might point you in the right direction.
/Cl
    SPATAN
SPATAN
Full Member level 2
Re: PID Control
I use for Temperature control.
my sensor is thermocouple.
Bluechem
Member level 4
PID Control
It deponds on the acceptable tolerance, needed response time, temprature range and consequences of failing.
raja_srs
Re: PID Control
For Temp. calculations using PID , U must have 5 i/p values,i.e expexted temp, absorbed temp form TC, P constant(PC), I constant(IC), D constant(DC)
then
1. error(praportional)=temp. diff
2. abs(error) * PC >100 goto line6
3. reset(integration)=reset+(error*IC) intial reset is 0
4. reset*PC >100 reset = PC/100
5. reset is -ve put zero
6. rate(Differential)=error-prv.error
7. add P+I+D
Fragrance
East Of Earth
Re: PID Control
hi
also look at that topic may help full for you
