what do u want exactly ?lyu said:when verifying a design , perl can be used to enhance your efficiency
eeeraghu said:how exactly can perl be used at the time of verification? one thing i know is it automatically simulates the desired testbench for a given test case, and can compare the output values, but this will be more relevant if people say, who already has done this.
eeeraghu said:Thanks Mr Omara, it was very useful information on giving one of the reason why perl is used in our field. But to my ambiguity can the perl invoke modelsim or else any other simulator or synthesizer and simulate accordingly to the instrictions given on the perl code? what i believe is it can be done but how?
eeeraghu said:Dear all,
Thanks for ur suggestions regarding this, and thanks Mr omara, we can use the DO file in modelsim, i.e we can run all the testbenches in oe go,
But what i actually wanted to do in perl is
There would be a different number of test case for different number of testbenches for a particular design,
so now if i want to simulate a design using a testbench and using a particular test case only, i can use an automated perl scripts which asks for what kind of test case to run at a particular period of time,
or else i do want to run all the test cases one after the other at one time, This can be done in perl.
Everything is fine i.e selecting the testcase and other thing but i am unable to run modelsim command.
Thanks once again
