greatmarx
Junior Member level 3
What is the via hole diameter,internal pad diameter?Does the via hole diameter contain the cu of the via?Does the via filled with cu or microvias is filled with cu?
Does the diameter of via is the same between the outer layer and the inner layer?
regard
Yang
regard
Yang
