Which USB chip is good for implementing connection to PC ?
lironz
built on an2131q
Which usb chip is recomended to implement connection to pc ?
thanks
sztibi82
Full Member level 3
Re: usb
Hi.
I suggest to use one of FT chips.
For more details check the site: www.ftdichip.com
There you can get examples, and schematics.
Bluechem
Member level 4
usb
it deponds on your project. you have basically three choices. 1- use a mcu which had built-in usb.
2- use a usb chip like pdiusbd12 3-use usb<-> serial chips
EleApollo
Member level 2
milan
usb
In my opinion, the product of the cypress is the easy to config and low-cost
vvsvv
Full Member level 1
usb
If you project use USB1.1 , then you may choose AN2131Q ;If you use USB2.0, then you may use CY7C68013 , both are easy to use and both form Cypress Co. Ltd.
presto
Member level 1
Re: usb
unless your project is sensitive to the cost, otherwise, 68013 (around 6~8USD) will be a good choice, as it has several automatic data channels, which can somehow 'DMA' your data from or/and to the FPGA. BTW, I also use this channel for quick run-time FPGA configuration.
vasureddym
Member level 2
Re: more on Cypress CY7C68013
hi vvsvv and EleApollo!
i need to know more about Cypress CY7C68013.
I want to know if on Cypress's CY7C68013 is better that ATMEL's At89C5131?
Could some one help me!
thanks in advance,
srinivas
