Which tool is better: Tetramax or Fastscan?
Vmanthapuri
Has anyone used both the tool for patterns generation to make apple to apple comparison and say which tool can give better results?
I am fastscan user all along and I would like to know if any anyone around here have any openions if tmax can handle any situations better than Fastscan?
like for example I know Tetramax can do "fault grading " using functional vectors but fastscan is not that well developed for that task.
I am wondering if any has experienced anything to say fastscan is better than tetramax or Vice versa.
any help will be appreciated.
Thanks,
~V
ls000rhb
Full Member level 3
fastscan tetramax
hi, Vmanthapuri, how to "fault grading" your functional vectors ?
Vmanthapuri
fastscan +tetramax
Fault grading has following steps.
Take EVCD from functional vectors
prepare them for tester by defining the events and strobes
Build model
then run DRC with nofile option
run vectirs in "good simulation mode' to validate simulation model and vectors as well.
then "fault simulate the vectirs to get the coverage.
the best coverage I could get was b/w 30 to 40%. It is clearly given in tetramax userguide as well.
Hope it helps,
~V
newcpu
Member level 4
fast scan tetramax
Fastscan is better from the DFT itself. TetraMax is better from the tools' understanding to logic.
somesh.24
Newbie level 2
fault grading tetramax
TMax has the capability for small delay defects(SDD) coverage which are missed in Transition Fault testing. Tmax SDD works on slack calculation information which it reads from SDC file. This feature at presently not well supported in Fastsscan
ljxpjpjljx
Advanced Member level 3
Shang Hai
fast scan model .v
in our company, we use the fastscan tool!
gracejency
Newbie level 3
India
fastscan tetramax author
Anyworkshops coming up for tetramax or fastscan
gracejency
Newbie level 3
India
fastscan2009
Hi friends i'm very new to this tool..How should i initially start up to work with this toollDo we have anyworkshops or training coming up for tetramaxin India... Or is the userguide more than enough.. Please help.
ahfoo
Newbie level 2
fastscan to tetramax
I feel fastscan is much better when compared to Tetramax.
It is very easy to understand even.
Run times are much faster.
Thats why it is costlier than TMAX.
But now our company is moving towards TMAX!
Cost reduction :(
shaileshdwd
Newbie level 3
INDIA
Re: fastscan to tetramax
Cost reduction :(
TMAX gives good coverage for IDDQ in comparison to fast scan.
and the compression ratio is good w.r.t xtol and pattern count.
Bit diificult to dfine the conditional or named procedure initially in the proc file (spf).
Else TMAX is also easier.
One advantage with Fast scan is capturing the values in setup mode is available but
this feature is not supported in TMAX.
Mainly helps P1500 controller sequencing.
With BR,
Shail
