Which tool can convert BOM-file to a Gerber file?
DR350SE
Junior Member level 2
I'm searching a tool witch can convert a text file (BOM-file) to a graphic viewer .
Input : coordinates X/Y and link to a component (IPCxxx standard)
OUTPUT : Gerber
Does that excist ?
cyberrat
Advanced Member level 3
In the sewers of the U.K.
BOM2GERBER Converter
Why? for what purpose?
If we knew more about your needs we may be able to suggest better.
Are you wanting to make Pick & Place machine files from this data?
What will you be doing with the data?
If for instance, your wanting to make a pick & place file, you will need Gerber data of the PCB panel, and then a textual BOM file which can usually be imported into Placement file creation software so that it matches up with the Gerber data.
I.E. Using GC-Place from Graphicode .com (or now GC-Powerplace).
But bear in mind that AFAIK there is no free software to do this.
Roland.
DR350SE
Re: BOM2GERBER Converter
I work in a +/- small smt assembly company .
In most cases we only have the pick and place files for the machines .
When I can use this files and link the components to a library(picture) so it would be possible to make a drawing of the assembly .
X-Y-ROTATION-COMPONENT>>>>LIBRARY>>>>DRAWING
(SMT MAESTRO is a free tool for this but no drawing)
And the second use of this
X-Y-ROTATION-COMPONENT>>>>LIBRARY/FOOTPRINT IPCxxx>>>>GERBER
(with this is it possible to see if a new project/pcb is drawn in a correct way for good assembly)
unisoft is something like that , but not cheap
