Which tool can be used to check that my chip has an EM problem?
hfooo1
Member level 1
which tool can i use to check that my chip has an EM problem?
and how to fix it
btw , anyone can share some good layout webs
thanks in advance
voltage strom cadence
Astro rail from synopsys does EM analysis...it does all power analysis at physical level.... there are other tools available from Cadence etc... (sorry....i don't remember names of all those tools !)
For layout below website is very good:
http://vlsitechnology.org
rgds
murali
http://asic-soc.blogspot.com
Re: electromigration
hi
ask one more question
should i analyse EM after both floorplaned and routed? or others?
3x
electromigration
You can use Voltage Strom from cadence to rectify EM problems....
You can fix this by increasing the width of the metal
but if it is excceding too much then u need to metal slotting which is dividing the lines on the metal to reduce the weight so tht it will not destroy ur silicon dioxide..
Electromigration is the one which depends upon the current density and the tool automatically choses the current density from( i donno u find out and tell me important question) and then calculates.It is very difficult to say how the tool calculates unless u work on that
Bye take care
and how to fix it
In general to fix EM problems either :
1. increase metal width.
2. Use decoupling capacitor.
Also you follow the electromigration rules in the design documents of the kit you use
for power critical designs it is recommended to carry out EM analysis after power planning...... if you find EM problem you counteract with increasing the power net width etc as mentined in previous posts.
hence it is very important to do proper initial power analysis at front end itself so that physical design engineer can do proper power planning.
rgds
https://asic-soc.blogspot.com
Does EM in PG net had some relationship with IRdrop?
acctually, it is current density, and related with Voltage, R C, right?
voltagestorm
and how to fix it
can you explain how the decoupling capacitor fix the EM problems?
some small trick if there's some EM violation on the PG(power ground) nets.
1 increase metal width (said as others)
2 use double layers metal (maybe triple)
3 make some holes on these metal(a little effect)
electromigration
what is the differance between lattice diffusion and grain boundary diffusion in metals, while undergoing electromigration.another question,can electromigration take place in semiconductorsb also?
