Which simulator is good for learning to program PIC ?
shultz
Newbie level 1
I am looking for a good simulator for learning to program PIC chips 16F84 etc.
Apart from MPLAB you can try miSim DE at:
It's a Java application. It has numerous interesting features. Suach as simulating a video display and an LCD and etc.
Regards,
direnc
I have found a simulator with some excellant pic examples both schematic and pcb layout can be generated as well as the code..... try Proteus.. its brilliant
seek the Proteus 5.x
your F628(2k) codes can simulates with
F84(1k) in proteus.its super software.
u will find all you need
use search engine find the parallax version of psim 2.43 i find it very useful
proteus is so
simple as tester
but you must debug
so mplabs a must.
for debugging, use MpLab.
But if you want to simulate a circuit with pic, the best is proteus.
So debug your pic's code with Mplab and see a global simulation of your entire circuit with proteus.
If you want to "learn" then you may want ot take a look at mICros, formerly known as PicnPoke.
It's for beginners, and do not require any microprocessor info. It has nice animated tutorials, an assembler you can use with your mouse, quizzez and more.
It's at http://www.bubblesoftonline.com/
An older version is available at BB's
FM, but the software is really very reasonably priced.
Regards,
Direnc
direnc do you have the full program of picnpoke
and Jum do you have the new version of virtualbreadboard. I have the old version
<font size=-1>[ This Message was edited by: nitr8 on 2002-03-08 00:57 ]</font>
Hi nitr8,
I have PicnPoke 2.61 and a keygen that works. Up from that version the author has cahanged the protection scheme, and I have not been able to find a cr@ck.
direnc
i' tried virtualbreadboard but it doesn't work fine
You can also try picutils (unix assembler+simulator).
h**p://w*w.ai.mit.edu/people/rsargent/picutils.html
Lad, your you work with the version 1.2 to the virtual breadboard?
