Which protocol to use for sending a data packet via ethernet
proton
Member level 3
which potocol ?
Hi friends,
I've the following problem:
in a measurement system I have 10 stations each equipped with an
arm7 board running uclinux. About every 10 ms each station has to send
a data packet to a master pc using ethernet. Which protocol should I use ?
I mean: I could have each node sending an email .. but doesn't seem the
right choice ... does exist a sort of master-slave protocol or something like
that ? examples ?
thanks
proton
which potocol ?
http://www.modbus-ida.org/
it works over tcp ip as well. Specs are downloadable at same place . Search forum and inet to find source code examples .
Research also internet protocols . I think you even can use http to send data.
which potocol ?
maybe the UDP is much better.
which potocol ?
I think that ressembles to the project i'm working on: we use CAN to do.
pm for more.
Re: which potocol ?
I'm interested to the UDP solution but if I understand well I should
anyhow define a protocol ... someone has C examples that I could use ?
thx
proton
