cupoftea
Advanced Member level 5
I was told by a Consultant level SMPS designer, (who was at the Marconi research place) many years ago, that the “Zetex” range of PNP BJT’s were excellent for use in PNP turn off circuits for high side FETs in LLC converters. This was, he said, because they have high hfe at high Ic.
Eg ZTX549 and FMMT718 and ZXTP2012A
ZXTP2012A datasheet:
ZTX549 datasheet:
FMMT718 datasheet:
https://www.mouser.com/datasheet/2/115/FMMT718-68167.pdf
..However, they have a slow turn on time of >270ns.
PNPs with much less gain at high Ic are significantly faster than this, eg 2N4403….
2N4403 datasheet:
https://www.onsemi.com/pdf/datasheet/2n4403-d.pdf
When i opened up an offline 750W Half Bridge SMPS, it was using 2N2907's fpr PNP turn off.....
2N2907 datasheet
So which do you say is best for use in a PNP turn off circuit?
ZTX549 datasheet:
FMMT718 datasheet:
2N4403 datasheet:
2N2907 datasheet
