s.manikandan
Member level 3
hi ,
i m designing 60w smps with input range 170-450VDC. multiple output. due to high voltage stress i chosen two-transistor flyback topology to reduce the voltage stress across the switch. Now i m in selection part of pwm controller and driver for the above topology.
1) how to select pwm controller ?
2) which parameter is vital for mosfet driver selection for two-transistor flyback ? i chosen the mosfet. what are all the parameters that i should take from the mosfet datasheet in order to select driver (high side and low side driver)
3) That is, how to determine sink and source current ? switching times ?
pls if possible, give some guide for above and explain with some example.
