hello,
I'm using IAR LPC2478 board.
Is there any suggestion of open source OS that supports CAN?
I'm very new into this field. Any help or guidance will be appreciated.
thank you.
There are several Open Source, but less complex RTOSs available, even rolling your own is an option.
As far as supporting CAN, that is a device specific feature, so you will need to use an available CAN API and write your own driver routines for use in the RTOS of your choice.
