Which metal is used for PAD connection ?
manish12
Advanced Member level 3
in ic layout which metal layer is used for pad connection,
for ex when i finish my layout there are in / out wires which has diff metal name .
can i connect it as they present ?
ro any specific metal layer i should use for PAD connection ?
forkschgrad
Full Member level 5
Philippines
Re: PAD connection ?
in a 3 metal process its's usually the highest metal.
manish12
if it not then ?
via ?
connection between available layers to metel3 or higher layers can be the solution ?
forkschgrad
Full Member level 5
Philippines
as much as possible when connecting block to block, connect it with lower metals. when connecting the core to pad u can use the highest metal.
Added after 3 minutes:
higher metals usually can handle higher current density.
