MAGMA uses .volcano libraries. You can convert your SCell, I/O and Macro
libraries into .volcano. You need .lib and LEF of them or you may use
also GDS instead of LEF. Usualy you may wish to convert LEF into MTcl
(MAGMAs´ Tcl extension) add or modify some rules and set them into
separate <your_sc_lib>.volcano. In case of I/O or Macro cells you just need to reference technology rules from the <your_sc_lib>.volcano.
Adding information for the noise analysis requires additional effort.
Look into Overview and learn the data model, then look the chapter about
creating libraries.
I hope it helps
I still not know how to abtain the volcano library through converting the standard library to the .volcano library. Please tell me more clear!!! thanks!
