Which EPROM emulator would you suggest?
sa007jbond
Who have experience which eprom emulator is relay good and
information where I can get or buy it.
I need for 8 bit only and for 8 and 16 bit eproms.
Reagards
elektor 1/2001 emulator for 27c256 eprom
hi mate,
here is a cheap but not versatile solution which I use on 8051 systems:
With a universal programmer (GALEP III) I program the code to a
FLASH-EPROM (AM29F010). Then I use an adaptor socket that makes it
look like a 27C512 to the µC.
I think you can also get 27F512 FLASH-EPROM.
But as I said: not very versatile. You'll have to use different adaptors
for different EPROM sizes.
wbr
thomaz
eprom emulator schematic
If emulating a 256Kbit EPROM ( 8 bit only)will suffice, the one in Elekt0r january 2001 is pretty fine. It works off the serial port and is based on a at89c2051. Source code and PCB is available at their web site. and the mag itself is available on another thread around.
27c512 emulator schematic
Which EPROM(s) are you wanting to emulate?
eprom emulator schematics
I use a Dataman S4 programmer, expensive though.
Enjoy
JSS
elektor eprom 27c256
I remember there was a project in Elektor Electronics, some
time ago. Can anybody provide us with a copy of this project ??
Thanks.
buy dataman s4
Here it is: ELEKTOR 1/2001 Emulator for 27C256 EPROM
Mik
elektor eprom emulator
Have successfully used a "HiLo" emulator on
a socketed pair of 8bit 256 eprom/flash chips
while I was writing the flash loader for the
system.
