Which DC synthesis warnings can be ignored?
engr
Member level 3
I am using the DC for synthesis, when i am using the "check_design" command before compile,report showing lots of warnings, i am confused which warnings are really needed to be removed so that we can go for compile.
Thanks in advance
Re: synthesis
without looking into the warnings, its difficult to say which can be ignored. After synthesis, use formality to check if the synthesis has gone ok. Other thing is: the design should 'link' properly.
Let me know the exact warning message, and may be I will be able to help
Kr,
Avi
    engr
Re: synthesis
If you can attach the report of check_design command to the post we can give you some meaningful suggestions.
    engr
