Which controller is more reliable for EMI/EMC
tectona
Member level 2
Hi, all
Microchip (16F, 18F & 24 Series)
Atmel (AVR or 8051 Core)
Cygnal
TI (TMS 430 Series)
Motorolla.
Regards,
Tectona
IanP
Advanced Member level 5
West Coast
They are all moretheless the same ..
Regards,
IanP
pawanbahl
all are equally good,provided you have followed good layout techniques and grounding. till date i have had emi issues severla times, but invariably the issue turned out to eb PCB layouting, gorunding and decoupling! so dont waste time finding the mst reislient device, but search something on pcb layouting for EMI/EMC.
turttle
Member level 2
Not exactly an EMI/EMC issue but as data years ago having an AVR on a grappling made prototype I had to add an additional ground return wire to avoid continous resets on the device. I never had such a problem on 8051 / HC08 devices with similar setups. I suppose even for equivalent performance devices internal clocking strategies depending on manufacturer make them more or less sensitives to layout flaws, ie. the greater the clocking edge coincidence among peripherals over common return, the greater the sensitivity on return inductance.
Cheers ;-)
Added after 17 minutes:
Just an advise: if you want a specially EMC robust uC, look for pieces close to ones commonly used in automotive industry (ie with avaliable CAN controller variants although you choose a CAN-less variant). Devices approved for automotive use are specially EMC resistant.
Cheers ;-)
