Which compiler is suitable for AT89C52?
lwecen
Newbie level 6
Hi, anybody can tell me which compiler suitable for this chip?
glenjoy
Banned
Philippines
AT89C52
You can use Keil C Compiler for that Chip. PM me.
lwecen
Newbie level 6
AT89C52
Thanks. Keil compiler seem like that i need to write code in 8051 Assembly or C , but not both.
Beside the compiler, do i need to have programmer
or anything else?
IanP
Advanced Member level 5
West Coast
Re: AT89C52
To program the microcontroller you will need to build or buy a programmer.
Here is a link to a programmer that you can build by yourself:
lwecen
Newbie level 6
AT89C52
Atually how does AT98C52 work with external EPROM?
IanP
West Coast
Re: AT89C52
It is a waste of time for me to elaborate on this subject if you can read about it here:
https://www.pjrc.com/tech/8051/dev-board-desc.html
(middle section). This site will also explain how to use external RAM etc.
Main thing, which you can find in the attached schematic diagram is that you need to fetch the lower part of the address (A7 -A0) and this is done by a 8-bit latch, such as 74373, controlled by the ALE pin, but this you will learn from that drawing ,,
xfilesb
Newbie level 5
go to www.Batronix.com
get program studio this is wonderful simuolation fot at89c52
and there are also the circuit of the programmer
www.Batronix.com
lwecen
Newbie level 6
AT89C52
how to switch between programmer and simulator in program studio?
lwecen
Newbie level 6
AT89C52
may i know which simulator/debugger is available?
Noman Yousaf
Full Member level 4
Lahore Pakistan
AT89C52
pinnacle52 profasional is the best assambler and simulater. check its demo ver. (limit to 2k code).
by search in google.com
i have worked on it. it is nice
fuzzy
Re: AT89C52
If attach /EA pin low.89c52 run external eprom
If you don attach low /EA and your software use over 8k 89c52 runs external eprom.
lwecen
Newbie level 6
AT89C52
How about the uVision2 Debugger? good?
ahm_hassaan
Member level 1
Re: AT89C52
Hi
uvision2 is good debugger, and easy to use for the first time, you can compile then debug your program.
lwecen
Newbie level 6
Re: AT89C52
Using 22.1184MHz crystal. if use timer 0 to measure time,configure Timer 0 as 16-bit time mode. if i want this Timer 0 to count up to 25ms then reset, what value should i put in the TH0 and TL0?
Below calculation is it correct?
22.1184MHz/12=1843200
0.025*1843200=46080
then TH0=0xB4, TL0=00
Thanks
