Which companies fabricate ASIC based on your design files?
BlackOps
Full Member level 5
AZERBAIJAN
if i design my custom ASIC, how can i get it fabricated?
which company fabricates chips based on my design files??
and how much would cost to fabricate one simple chip??
thanks
hrushitha
Member level 1
Re: fabrication of ASIC
hi,
a single chip can't fabricate,becoze it is very costly,number of chips make on a single wafer.wafer cost also increases day by day with technology.
regards
vak
Member level 3
Fabricating single chip is not feasible. Generally, a wafer lot of 6 is taken up by the fabs.
Say for example, if it is 8" wafer and your die size is 8*8 , you can expect around 400+ good die.
Cost depends on how many units, you wish to make.
truebs
Full Member level 5
Asia
No company will facbricate your design based on your design file...
You'lll need to confirm to their design file and other design constrainsts to get it fabricated.
and comments above regarding single chip are true....
You should try using FPGA in case its possible for such applications...
If still you'd like to get it fabricated, you may tak with some companies (if you have contacts and send it across to founday through them along with their dummy designs )...Many companies do that....but that's not possible for individuals....
some companies that fabricate are : TSMC, CSM, XFAB, IBM, TOWER, etc...
gbaerf
Full Member level 2
belongs to whole word
fabrication of ASIC
exactly u can try it out on FPGA ...
ASIC fabrication is done usually on bulk not for a single designs ...
most of the foundries are there inTaiwan...
sohiltri
Member level 5
agree tht fabrication cost much......but if u hav done all homework like layout ...timin anaysis ...routin....i mean complete backend flow....and if your university sponseres u can send your .gds file to certain fabrication foundaries....yes for test purpose they do fabricate.....certain foundaries have tieup with universities....
for eg u can submit your design to TI ,which accept in nov and feb for fabrication....
bharat_in
Member level 4
@sohiltri,
Can you please tell the name of some university, which have tieups with foundaries?
