which book to learn picc (hitech)
hakan
hi,
is anybody know that how can i find information abouth picc (hitech) easier than it's manuals.
i think, i need some basic information abouth ansi-c for embeded systems.
i will buy a book. But which one?
Check this link "Program Microchip PIC micros with C":
https://www.microchipc.com
and search the forum - some days ago the book "Embedded systems programming with C and C++" was uploaded.
Ace-X.
Hi Hakan,
If you already know C, the the best way to learn Hitech is to look at example code from web page such as:
You will find many tricks to make the PIC hardware do what you want.
Also, read the PIC data sheet to fully understand the hardware.
The HighTech is only ANSI-C and has zero suport for the PIC harware.
You must control all the PIC hardware yourselt.
Also, you must manualy map all variables to the PIC memory banks with the HighTech compiler and the code it generates is not re-entrant.
I have used HighTech, CCS, and PICC18 for MicroChip. I believe that the best compiler for pic18 is Microchip PICC18. Its not the most code efficient but it is bug free and easy to use since it includes drivers for all the PIC hardware.
ServoPump
Hello, hakan
If you go to the below linx, may you can find someone experiences and
try & errors know-how on PI@CC support forum.
Good luck.
:roll:
