arbj2
Full Member level 3
I am just stepping into ARM development using M0 Cortex 32 bit mcu, with C/C++ languages specifically. For this now I am using the Teensy LC board, this uses the Freescale Kinetis MKL26Z64VFT4 mcu, with the Kinetis SDK and IDE. My question is which of these are better ??
I have also found this from Cypress which is quite cheap compared to the 25Z from Freescale.
Cypress:
https://in.element14.com/cypress-se...xx/prototype-board-cy8c4245axi-483/dp/2420489
https://www.farnell.com/datasheets/1812575.pdf
Freescale:
https://in.element14.com/freescale-...dev/dp/2191861?MER=MER-BPR-4PPM-SP-FSALMC-SMT
Basically what I am looking for is a platform that can be easily converted into the finished product, the cypress for example has a prototype board that can be broken off from the programmer and used in the actual product. The Kinetis has more components which I dont need. The Teensy is also cheap and has a bootloader that is useful.
My question which is better platform, and has better chance of being supported..Also are there any boards, prototype ones that support USB host capabilities ??
thanks
a
Cypress:
Freescale:
thanks
a
