Sumathigokul
Member level 1
Hi all...
I have two doubts.
1. My first doubt is how to write the tcl script which locates my existing .vhd file and insert new line of code in it or replaces some of the existing codes and save the modified .vhd code back to same folder or in another new folder???
2. My second doubt is if i want to modify .vhd code already existing (statement of my first doubt) using TCL command, how i can perform it? for example, to force any value at .vhd file using tcl command, am running that particular command in any of the simulation tool's command line. Similarly, if i write a tcl script to modify .vhd file, where can i run that file (i.e. using which tool) ???
Regards,
Sumathi G.
I have two doubts.
Regards,
Sumathi G.
